Go to Post I can't get anyone on the team to leave warm South Florida to go to Manchester in January. Go figure. - Warren Boudreau [more]
Unread 06-23-2014, 02:26 AM
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Re: pic: Too much power?
Originally Posted by Andrew Lawrence View Post
More like not enough material. Those thin pieces of sheet wouldn't hold up on their own even without the motors. At a minimum, especially for anything with a CIM attached to it, use 1/4" aluminum plate, or else your gearbox is going to snap before the first miliamp hits your motors.
You don't need 1/4" plate.. Yes, it is more stable for gearbox application, but I have done my share of research on sheet metal gearboxes and 971 does just fine with what it looks like .090". I looked through their entire album and they use A LOT of .090 for the chassis. Granted I will have 2 more motors per gearbox.. Either way. If you don't believe have a look for yourself. If it is not strong enough, I will A)Put a flange on the plate B)increase the thickness to .125" C)Do Both.
971's 2014 Gearbox:
https://picasaweb.google.com/1177698...88397646577634
With 8 motors I am trying to get more acceleration (mainly), and more pushing power. Spectrum ran 8 this year and really liked it so I figured I would give it a try. If it doesn't work out I will go with 3 CIM
