06-26-2014, 10:58 AM
Re: pic: Too much power?
If you're attached to .090, here's an off the wall idea: Make your output shaft a dead axle, and use VersaHubs and bearing bore gears / sprockets to couple everything together. That way you can make your axle a standoff, serving as a structural member of the gearbox. This adds rigidity right where you need it.
Considering it's sheet metal, flanges are basically "free". Some teams use the flanges to stand off the gearbox instead of standoffs - this is only really an option if your sheet metal shop is really good at holding tolerances.
