Go to Post Dont give up, because that is when you lose what you have. FIRST is the best experience that I have had throughout my entire life and there is no way ANYONE can make me quit FIRST. - Arefin Bari [more]
Unread 01-07-2014, 15:03
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Re: pic: New serve mk.1-2517
Originally Posted by Tyler2517 View Post
We do not want 2 of the same material gears so we don't have to grease them so carpet cant get stuck in the grease.
I understand where you come from with this idea, although the power that the gears with transfer will need grease, no matter what type of material you use. I know that carpet fibers and other junk gets stuck in normal grease, but you can also use dry grease. Machining tools (boring bars/milling disks) use dry grease so chips don't get stuck between important seals. I would look into using dry grease because of the low friction index, such as Dry Graphite Lube (I once used it to win a pine-wood derby).
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
