Re: pic: WCD Sheet Metal Hybrid
We inquired about an order through Coast Aluminum last year for that material specifically and it didn't work out because shipping to New York was prohibitive for them. However, we were able to find 0.080" wall 2 x 1 6061 aluminum rectangular tube through Alro Metals. It arrived with a kink in the middle, likely from shipping, but we were able to use the material on either side of the kink anyway with little waste. We used this for our rear rail and bumper supports on our WCD. We used 0.125" wall on our front rail due to concerns about the stresses on the frame in that area from our 4 large torsion springs, but I would venture to say we would use 0.080" on that front rail in most years moving forward.
Check out page 10-52 http://www.alro.com/datacatalog/010-...um.pdf#Page=52 |
Cory,
How about slotting the top of the 1 x 2 tubes so the bearing blocks drop in from the top. Once tighten the bearing block becomes integral to the frame and strengthens the tube. That would make your transmissions and wheels drop right in. Using 6061 T-6 for your belly pan would be fine if then is no bends. Laser away. There is a process called bump bending in which a series of small tangent bends along a radius which used to create a large radius bend in sheet metal. You can use that process to bend T6. T6 Sheet stock just requires a large inner radius or use of a wrapper while bending. If you are worried about your front/back bending in you could attach a small hat section of sheet metal behind the front and back along the length. This also could serve to be the mounting rail for the manipulator. I think being able to mount and adjust the manipulator is very important in a design. Here's another idea. How about making the front and back circular? You have a good start. Last edited by roystur44 : 03-07-2014 at 18:19. |
Hey Roy thanks for the reply. Sorry it took me a bit longer to get back to you. The 4th was a bit in the way this past weekend!
Thanks for all the help! |
