Go to Post I can't think of a match where we didnt do the ritual. We always called it... "Deploying the code" - Briansmithtown [more]
Unread 05-07-2014, 16:39
Andrew Lawrence
Re: pic: FrameDrive 6wd Concept
Ah, but that is a bit of a stretch. Belts and chains both stretch over time, especially for the first little bit right after they're put on as they wear in. Having no provision for dealing with that is asking for trouble. If you design for the final distance, the initial belt tension is going to be a bit tight, running the potential risk of a catastrophic stretch. If you design for the initial distance, you're going to be fine at first, but a little bit sloppy/slack later. Split the difference and get both sets of issues. It won't be much, but it will probably be enough to be noticeable.
There are a number of ways to deal with this--sliding bearing blocks come to mind as the typical WCD solution--but if you don't want to design tensioners in, probably the easiest solution to add later is the "floating idler" tensioner--drop a slightly larger-than-the-rest pulley/sprocket into the middle with no anchor and let it find a spot where the tension is right. Second easiest is a small spring-loaded pulley; install and use the spring to push the top of the chain or belt upwards a touch to increase the tension.
A 15mm HTD belt put in C-C distance should not stretch during an FRC lifetime to the point where it loses tension. IIRC 2791 runs their belts C-C in a WCD-style setup with two 15mm belts, and hasn't had tensioning problems yet, though if Chris could weigh in on this I'm sure he can describe their experiences better than I can.
All in all, you should be fine with C-C tensioning for belt in an FRC application. While I cannot speak for C-C, our belts this year had tensioners designed in that we never used because the belts didn't gain any slack (that is, while they were still in one piece - but that was in part our fault).
