Go to Post I've got it! INFLATABLE clown fish!!!! - dlavery [more]
Unread 05-07-2014, 17:37
Joey Milia's Avatar
FRC #0192 (GRT)
Re: pic: FrameDrive 6wd Concept
If you're running 9mm wide belts you should have adjustment to tension them correctly. If you're running 15mm wide fixed c-c would be fine. I would suggest adding up to 10 thou to the calculated c-c depending on belt run length, pulley size, and the specific belts you'll be using.
