Go to Post Before anyone accuses FIRST of being in the pocket of the sponsoring corporations, they might spend a minute and a half to actually apply some of that critical analytical ability that we are supposed to be demonstrating as educated engineers. - dlavery [more]
Unread 05-07-2014, 21:56
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: pic: 8-Wheel Chassis
Originally Posted by Tyler2517 View Post
I am exstreamly interested in the octagon frame, and what design decisions did you use to come up with it what advantages do you think it will give you?
Why the 8 sides with such steep corners?
My team used a similar octagon frame this year, with 4.5" sides on a 45deg angle. These corners are 5" long in a 3-4-5 triangle arrangement. Although this makes for some weird angles, it means that all of the side lengths are whole, rational values (in other words, less math ). Octagon frames have a few advantages:
-It allows you to have more inside surface area while staying inside a 112" perimeter.
-Defensive robots can't hit your corners. This doesn't sound like much, but any robot with omnis as outside wheels can easily be bumped out of position by a corner push.
Originally Posted by magnets View Post
I would not set up the wheel axle bearings the way you have them now. I would definitely use some type of bearing block so that the bearing is well supported. Right now, all the load on the shaft is concentrated on only .125" of the bearing.
Yeah, a bearing block would be used. The bearings in the model are just there to say that a bearing goes in that general area.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
