Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 06-07-2014, 03:17
Re: pic: FrameDrive 6wd Concept
Originally Posted by Infinity2718 View Post
Assembly and maintenance is a concern of mine as well. I would like to build and test before using during the season, if that is a direction the team wants to go. It is tempting because it opens up quite a bit of room and lowers the cg a bit.
I went through and checked the weight, and it is 34 pounds with the motors (without the electronics). I'm not sure if that is higher or lower compared to other drives, it seems around the same weight we normally see.
34lbs is pretty good for a 4-cim drive. Optimal would be 30lbs or even less, but 34lbs is quite repectable conidering you have the tubing that hangs over the wheels for mounting stuff. Sub-30lb drives tend to be just the base and motors.
