Go to Post Almost as if there's...co-opertition? - Michael Hill [more]
Unread 07-08-2014, 03:54 AM
FRC #1678 (Citrus Circuits)
Re: pic: 4587-Sheet Metal Chassis V.2
Originally Posted by Cash4587 View Post
How about this?
This isn't too bad for complication and it saves so much room. Although it does cost quite a bit for the bearing bore gears and for the bearings, It will leave plenty of room for electronics, at least I would say so.
http://prntscr.com/40ilna
http://prntscr.com/40ile3
I like it, I think you've got the right idea. You could totally get away with this but here's some thoughts.
What made you choose a dead axle over live axle? And in this setup do you plan to cantilever the gears? I think you could save weight if you ran live axle gears as you could fit a much smaller gear in between the cims.
I think you could simplify it a bit by removing one of the gears between the gear on the module shaft and the closest cim.
I could be totally wrong here, but in those renders is the robot not as long?
-Adrian
