Re: pic: New serve mk.1-2517
a bane bot 775 (i think) on a 132:1 ratio is what we used this year with no problems, and most likely what we will use on the prototype, if we have any issues we may use a different gearbox, or find a way through code that the wheels never pivot in place, only when the wheels move forward/backward will the assembly turn, but this is what we are prototyping to find out.
Nope I was wrong. 430 is probably a typo, there isn't a banebots 400 series as I assumed.
That's, kinda, not on the list of approved motors?
We used the 540.
We designed initially to use a 400 series moter with a moduler mounting plat to the gear box. Ended up using a 540. |
Might be this guy, I believe it was legal at some point in time. But with the current motor allocations teams should just use the 550 or the 775. |
