Go to Post You need to stay on top of your classes or you will be back as a returning freshman on next year's team. - [more]
Unread 09-07-2014, 11:25
asid61 asid61 is online now
Re: pic: New serve mk.1-2517
Originally Posted by kk052 View Post
it was argued about in the design process about the use of a diff, we decided not to to save space and make the unit simpler, and the less things to go wrong the better, also if there are any ramps in the 2015 game and one side of the wheel gets on it, all the power will be given to the other wheel. we are going to have to use a lower ratio to turn it however
As long as you use a beefy turning motor (not a window motor) you should be fine.
