Re: pic: First Sheet Metal Drivetrain CAD
Here's version 2 that incorporates AustinSchuh's advice and adds other improvements including:
-Easily removable gearbox connected via gear to the axle (like 971's recent robots). Increases belly pan space and simplifies belt mounting. -Outer wheel bearings are in sliding blocks tensioned with cams, allowing for better belt performance. -WCD-style pulley mounting allows for belt changes without removing wheels. -1.8lbs lighter ![]() Closeup of cam and bearing block. There's an identical block and cam on the outside. Anyone see problems with this setup? ![]() Last edited by z_beeblebrox : 19-07-2014 at 16:09. Reason: Added images |
The gearbox as you have it looks pretty difficult to manufacture. Extremely deep and narrow U-channels like that are hard to make with a press brake without some specially designed tooling.
Or is that two pieces? It's a little hard to tell. Either way, I'd suggest using a flat panel that bolts to the outside of the chassis rail instead. Laser cut bolt holes hold much better tolerances than bends, and you have to keep things pretty tight when center-center gear distances are concerned. |
As per Joe G.'s advice, the gearbox is now two plates. The lightening pattern is improved and an access hole for the outer tensioners is added.
I've found it really nice to have a square cutout above our wheels, and cutouts in the frame big enough for hands. That makes it really easy to see how your wheels are wearing, and to get your hands inside if you need to do something. |
