Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
  #31   Spotlight this post!
Unread 27-07-2014, 10:40
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: #NotSwerve
Originally Posted by Andrew Lawrence View Post
Teams that gear for that speed use it in cases where you would want to cross the entire field extremely quickly in one straight shot (think 2011 or 2013). That being said, it's still something interesting to test. Most robots that run these speeds are on the lighter side (90-100 lbs), which helps them abuse the higher speeds with greater acceleration.
They do. However, in my experience, the risk of blowing the main breaker here is not worth it. It also necessitates a drive system such as split arcade for decent control.
We're considering going to ~16 calculated high and ~7-9 calculated low next year to avoid blowing the breaker.
  #32   Spotlight this post!
Unread 02-08-2014, 04:53
asid61 asid61 is online now
Re: pic: #NotSwerve
Main breaker blows can be easily avoided by implementing a "crash detection" current-sense code. Use a current sensor to check if it is a spike. If the current spikes for too long, you shift to low gear or put the CIMs in brake mode.
If you are using a shifter, I think going 18-20 fps is not all bad, as long as your driver can control it.
