Go to Post Find what your team is good at, and use it in any way you can. - karomata [more]
Unread 01-08-2014, 20:22
Jared's Avatar
Jared Jared is offline
Re: pic: 3216 Swerve
Originally Posted by ekapalka View Post
Hmm... I was told that properly spaced pulleys wouldn't require a tension system :/ I guess I'll get looking into how that's done. As for the bearings, do you have a ballpark estimate for the prices they offer? I like the weight and look of them, but the bearings I've found are only $19.
If you can get the center to center distance correctly, like if you're doing it on a mill/CNC, you won't need tensioning.
Silverthin bearings are nice, but really pricey. If you've got the room for thicker ones, you could save some money. I know 1640 uses a large ball bearing, a large thrust bearing, and a bushing on top.
