05-08-2014, 12:49
Re: pic: 4WD Concept
Originally Posted by JohnFogarty
These bearing blocks though designed to work similarly to 221 systems blocks are in fact somewhat custom. 4451 and I CAD up these versions ourselves and then CNC milled them ourselves. They used this version on their 2014 6WD drive-train without issue. When you say the bearings were spaced (distance) apart, are you referring to the distance between the two bearings inside the block?
I was referring to the distance between the bearings, as that determines how well the shaft is supported and how loaded the outer bearing is, but it seems like that's not a very big issue, especially if you've successfully done it before.
