Go to Post Besides, if you look back on anything you've already made and can't find any flaws that can be improved, you're doing it wrong. - artdutra04 [more]
Unread 05-08-2014, 14:07
kk052's Avatar
kk052 kk052 is offline
CAD extraordinaire
AKA: kyle lundquist
Re: pic: 3216 Swerve
Originally Posted by ekapalka View Post
The problem I'm facing is that the absolute encoder/potentiometer needs to rotate with the module 1:1. The only solution I have been able to come up with is to have a separate series of gears originating from the VersaPlanetary at the same ratio as the belts, but I've run into found a few issues with that (stemming from the short VersaPlanetary output and/or vex and andymark gear thickness). I'm trying to keep as much as possible contained within the plates that make up the body of the module (and I'm trying to go no higher than 1.25" from one to the other). I'm sure there are a lot of ways around this I haven't thought of... [EDIT] I could use a motor other than the BAG motor with a lower RPM and have 1:1 pulleys turning the module. Then mount the sensor right on top of the VersaPlanetary
Hmm... I was told that properly spaced pulleys wouldn't require a tension system :/ I guess I'll get looking into how that's done. As for the bearings, do you have a ballpark estimate for the prices they offer? I like the weight and look of them, but the bearings I've found are only $19.
Even if my team actually decides to go through with this and build it (which I'm almost certain they won't), we're probably not going to use it in competition because of the technical problems that undoubtedly go along with swerve.
I was wondering if anyone had any thoughts about holding the pivot yoke to the rotating module using screws (8xM5). Its not something I've seen done, so there's probably a reason...
screws can be inacuate, also how are you planning on putting a pully on if you cant change the center distance in any way?
2012 Autodesk Oregon regional
Unread 05-08-2014, 14:15
Data Nerd
FRC #0079
You could always use an incremental encoder and an index (limit switch of some sort) as a zero.
