Go to Post Well, the cake could either be a simple cake Or It is blue, so that obviously means that we are having a water game this year. - big1boom [more]
Unread 06-08-2014, 12:42
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: pic: 4WD Concept
Originally Posted by JohnFogarty View Post
I honestly don't know why this would occur. The turning scrub of this drive-train would be noticeably less than that of a 6WD.
...snip...
It would depend on the CG location. Let't take a couple of extremes and then this might make sense.
1. If the CG is really close to being over the top of the omin-end, then turning can be difficult as the traction wheels act a bit like a rudder.
2. If the CG is nearly directly over the top of the traction wheels, then there will be very little lateral from the omnis which can make it difficult to drive straight.
1 can be a very bothersome configuration as you would get pushed around easy without the benefits of being really maneuverable.
2 can be difficult to drive in a straight line, but should be very very maneuverable.
There is a white paper by Chris Hibner that you can use to set up a calculator and play around with values.
