Go to Post A team pulls together when things get rough. - Aignam [more]
Unread 09-08-2014, 19:19
Sam_Mills's Avatar
Sam_Mills Sam_Mills is offline
FRC #4965 (FIRE)
Sam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond repute
Re: pic: 4WD Concept
Originally Posted by Bryan1625 View Post
Well I wouldn't consider this one of the worst drive trains. Done right it can be a very competitive drive train. With practice you can out manuver a swerve and have more pushing power then a low gear on an 8 wheel or 6 wheel tank. It just takes trial and error on which wheels you want to use and the driver and the set up of the gear box
By no means do I think this is a bad drivetrain setup, I was only trying to assert that even if it was, any negative aspects can be mitigated with practice to the point where practice is arguably the most important thing. I really like how hard it is to lock this setup in a friction pin, as well as how light weight it is.
I don't really understand how it is supposed to be able to push better than a 6 or 8 wheel tank though, considering that both robots are allowed the same motors, but one has more torque and a higher CoF with the floor.
Edit: (not that pushing is necessarily important)
2013 MORT 11: Captain/Driver 60 - 19 - 1
2014-current FIRE 4965: Engineering Mentor
ewcp 2013-current
If you argue with math, you are going to lose.
