Go to Post Engineering is a career of continuous learning, acquiring new skills, and growth. - KenWittlief [more]
Unread 08-15-2014, 12:13 AM
Electronica1's Avatar
AKA: Alexander Kaplan
pic: FRC 1086 Off-season teaser #1
Unread 08-15-2014, 12:14 AM
nathannfm's Avatar
AKA: Nathan
FRC #3940
Re: pic: FRC 1086 Off-season teaser #1
Very nice, looks like everything could be done without a mill or maybe even a lathe, correct?
Unread 08-15-2014, 05:40 AM
Looks good. Is that the only support plate, or will there be a second one beneath?
Unread 08-15-2014, 07:43 AM
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
I'm guessing not photography?
http://www.mcbride4.org/?attachment_id=207
The sooner we get behind schedule, the more time we have to catch up.
Unread 08-15-2014, 07:46 AM
We actually did use a lathe, but we were able to avoid using a mill.
That is the only support plate. The module mounts nicely with the old style kop c channel.
Unread 08-15-2014, 08:10 AM
Gdeaver Gdeaver is offline
FRC #1640
Can't see inside but, That hole looks like it is for accessing a set screw. The transfer axial should be designed so that the axle is constrained eliminating the need for a set screw. Racking. What is going to keep the lower module from becoming a parallelogram under high stress and load? Did you use thrust bearing for the miter gear loads or are you putting this on the ball bearings? What wheel is that? Allot of cantilevered load for that single mounting plate and those welds. How is this going to be driven? Is it a module or are you going to use a separate power pack? Only way to know what you got is to put it on a fully loaded robot frame and drive the hell out of it. See what wears. Igus bushing instead of bronze?
Unread 08-15-2014, 10:56 AM
JDGallagher's Avatar
JDGallagher JDGallagher is offline
AKA: John Gallagher
FRC #1086 (Blue Cheese)
JDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of light
There are internal support braces that will keep the lower part rigid. It is a module. 1 Cim 1 mini cam per module. Also it's worth noting that on the final version we will be using our own custom 2" performance wheel instead of the wheel you see there.
Unread 08-15-2014, 10:59 AM
AKA: John Gallagher
It's also worth noting that the internal support is not visible in this picture because this version of our design hadn't incorporated them.
Unread 08-15-2014, 11:02 AM
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
2" Diameter? How concerned are you with the wear rate?
With Live axles I'd suggest taking a look at other solid rubber wheels, perhaps a Colson.
Unread 08-15-2014, 11:35 AM
AKA: John Gallagher
We've considered colsons and used them before but our CAD team tells us that performance wheels are significantly cooler looking.
Unread 08-15-2014, 05:38 PM
mrmummert's Avatar
mrmummert mrmummert is offline
AKA: hank
FRC #1610 (bot)
mrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to behold
Send a message via Yahoo to mrmummert
Is this something we'll see at the Rumble in October?
winner vcu 2006,winner vcu 2013,2014,2015
Unread 08-15-2014, 08:19 PM
nathannfm's Avatar
AKA: Nathan
FRC #3940
It is a module. 1 Cim 1 mini cam per module.\
You mean 1 CIM to drive it and 1 Mini CIM to turn it?
Unread 08-15-2014, 08:38 PM
No, we were looking at how some teams were running 8 motors to drive their octocanums, so we thought it would be cool to give the same treatment to swerve. We use andymark motors to turn them.
Unread 08-15-2014, 09:07 PM
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
So a 12 motor drive.... Sounds like a lot of power draw....
Unread 08-16-2014, 06:22 PM
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
Looks like exactly what the off season is for. Make sure to post lots of puctures, and maybe a writeup when you're done? I really like the idea of a lower barrier of entry for swerve.
Good job, keep us updated!
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
