Go to Post Finally, they're getting rid of the spotlights. I'm sick of seeing ridiculous inside jokes up there. - Karthik [more]
Unread 23-02-2003, 15:59
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: Self-Righting
chellyzee93's Avatar
chellyzee93 chellyzee93 is offline
Schuff Rocks my Socks :)
AKA: Michelle Zimmer
#0093 (NEW Apple Corps)
Team Role: Student
chellyzee93 has a spectacular aura aboutchellyzee93 has a spectacular aura about
Send a message via AIM to chellyzee93 Send a message via Yahoo to chellyzee93
That is a good idea. I know a lot of teams are having troubles with that.
Team #93 New Apple Corps
2004 Xerox Creativity Award
2004 St. Louis Regional- 5th Seed
Just waiting for that second wind to kick in
-Chell
Unread 23-02-2003, 16:09
Willum's Avatar
Willum Willum is offline
#0871 (Robotechs)
Willum is an unknown quantity at this point
Send a message via AIM to Willum
This being a discussion i wanted to raise this point. If this robot were to fall on it's "face" would it be penalized for metal in contact with the rug? Possibly shut off for the remainder of the match? Our robot has a similar idea with our arms. Any ideas?
Unread 23-02-2003, 16:24
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
As I see it, the rule against metal contact with the carpet is aimed totally at stopping damage to the carpet. If your arm or other mechanism is round aluminum tubing, I wouldn't worry. If it's sharpened carbide spikes, you might want to make some changes.
In either case, as long as you have ANY weight at all left, some timing belt or thin poly carb and some pop rivets could alleviate any doubt.
Also, during inspection or even before, ask FIRST. Most, if not all, the inspections I have witnessed has had a very thorough check for sharp metal edges on all components, including arms. Might be a good time to mention that your arm can be used for self-righting by pushing on the carpet.
Adam
"My favorite programming language is solder."
- R A Pease
Unread 23-02-2003, 17:12
LoganB LoganB is offline
Echo 7
LoganB is on a distinguished road
Nice work just 2 questions
1. Is everything mounted so it can take the impact of coming back down?
2. And this device doesn't get caught on the lip of the ramp and carpet when they meet?
Unread 24-02-2003, 11:43
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Reject False Icons
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
The device dosn't get stuck in the ramp. It is flat on one surface and has lexan sticking up on another to pick up boxes. It can work on both the ramp and on the carpet. Everything is also built to withstand a fall. We have reinforced our casters and have our electrical board in there nice and tight.
Steal back your future
Unread 24-02-2003, 13:39
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
just out of curiosity... do you have enough clearance to back up the ramp? (I'm assuming the casters are on the front)
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 24-02-2003, 13:49
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
I think my teams flippy robot should invest in something to keep us from flipping.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Joe Matt's Avatar
Reject False Icons
We have enough clearence to go backwards and forwards up the ramp.
tehehehe
Unread 24-02-2003, 13:57
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Yeah, it took our team a long time to get to what we finally built, we went through tons of ideas and designs, and now we have a fully functioning robot that will do what we hoped it would. But lets just say we drank many bottles of Bawls.
~Mr. Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 24-02-2003, 14:04
Joe Matt's Avatar
Reject False Icons
~Mr. Ivey
Bull.
Unread 24-02-2003, 14:53
KevK's Avatar
KevK KevK is offline
#0121 (Islanders)
KevK is an unknown quantity at this point
Question Casters??
just curious, do your casters get stuck at all on the wire mesh, or do they make the robot bounce around? nice righting bar/box lifter!!
121 used to stack, unstacks, and gently removes robots from the ramp!!
Unread 25-02-2003, 10:33
jmo8605's Avatar
jmo8605 jmo8605 is offline
jmo8605 is an unknown quantity at this point
Send a message via AIM to jmo8605
Our casters do not get stuck and we do not have a problem with bouncing. we found the right size casters for the job
Unread 25-02-2003, 13:27
Joe Matt's Avatar
Reject False Icons
Our casters are big enough to not get stuck and we don't bounce around at all. But it does make quite a bit of noise.
Unread 25-02-2003, 13:41
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
sweet innovative design, Its good to have thought of flipping before you actually flipped, i'm hoping our team bot doesn't have a problem with flipping
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
aerial image of your School MattK Chit-Chat 46 25-02-2007 20:08
Getting Rid of Image Discussion of Who Am I Gallery Melissa Nute CD Forum Support 44 26-02-2003 21:48
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
Robot Mechanisms Image Database archiver 2001 0 23-06-2002 22:14
image upload max size Mike Soukup CD Forum Support 3 26-11-2001 11:29
