Go to Post I also would not recommend shipping the gerbils with the robot. - Stuart [more]
Unread 17-08-2014, 12:32
Jared Russell's Avatar
Taking a year (mostly) off
Re: paper: Driving a Robot — Fastest Path from A to B
What you have brought up is a special case of a well known theorem from optimal control that says (essentially) that you always want to be saturating your inputs to get to the final state in a time optimal way. Intuitively, if your left and right motors are always going full speed in the right direction towards your setpoints (both position and angular, and you've found the right turn-straight-turn policy that ensures that this is true), you will always get there faster than if they are not going full speed all the time.
This property holds with an infinite acceleration limit and, indeed even with limits on acceleration, jerk, etc. - except in the latter case, you always want to be accelerating/jerking at the limit. The complication is that once you introduce higher order constraints, the "order of operations" policy becomes difficult to discover because of the nonlinear mapping between motor speeds and position/rotation. Once you have higher order constraints, finding a time-optimal path becomes a more difficult process, typically requiring iteration and search in a non-convex space.
If you look at 254's acceleration profile generation code from this year, you'll see this concept in action - using a triple integrator with an input that always switches between +1/-1, we obtain a limited-jerk, limited-acceleration, limited-velocity trajectory. We then applied this acceleration profile over a spatial spline, which of course broke the time optimality but was good enough in practice (with some safety margin to prevent saturation).
So...Yours is the right conclusion if you ignore practicalities like acceleration limits, wheel slip, battery usage, dynamics/momentum, and jerk to the robot and any load(s) it is carrying. Empirically, these are quite significant factors for FRC driving:
* Robots that have high enough maximum accelerations to allow you to assume instantaneous acceleration will frequently also be capable of slipping their wheels, harming control, acceleration, and accurate distance measurement. Moreover, by the time you are talking about full-weight, 15+fps robots, the infinite acceleration assumption breaks down severely.
* A robot that moves from one point to another along an arc does not need to repeatedly accelerate and decelerate the drive motors as in a turn-straight-turn case. This saves battery life, heat, and wear-and-tear over the course of a match. The battery life savings can be significant enough that it allows you to gear your robot faster overall.
* Momentum is a HUGE part of FRC driving at high speeds. If I take a 254 robot at 19fps and want to turn, I can do so on a dime simply by slowing down one side of the drive and letting the momentum whip the back end of the robot around the corner. Maintaining momentum through maneuvers is generally preferential to coming to a stop.
* Even if you have an infinitely accelerating robot that doesn't slip its wheels, has a perfect battery, and doesn't care about momentum, if you are carrying a game piece externally, you may want to reduce the accelerations and jerks experienced by them. Case in point: The balls we held on our bumpers during auto mode this year could be dislodged by a very abrupt stop or quick turn in place.
