Re: pic: New swerve CAD from 2471
Hmmm... looks somewhat similar to one I've seen before...
just make sure the C brace the swerve's attach to are not shaved completly flat, or you might lose strength in the frame. also are you not worried that the belt might slip off the larger gear because its not flanged? also most years bumpers must be supported every 8 inches do they mount on the swerves, or is there an additional bracket that is hidden? Last edited by kk052 : 18-08-2014 at 19:28. Reason: added something about bumpers |
Well you certainly won't be winning any pushing battles going that fast but on the up side, if it works as well as last year, maybe you won't need to!
I still think its geared a bit high. |
Even so, I would be worried about collisions at that speed on the modules. A hard hit on a corner could render you immobile, as well as costing a few hundred dollars. Even if nothing breaks mechanically, encoders are pretty fragile. With frame perimeter rules, are you really gaining extra room this way? |
It's also going to impact acceleration. I suspect being geared that high the robot will seldom actually get to top speed during a match before having to change direction. Usually robots geared that fast will have six CIM drive trains just for that reason.
I think you'll find that a robot geared for 14 fps on 4 cims will have plenty of power to accelerate quickly. Our comp bot did fine this year, and it was geared for about 18 fps. Our bunny bot was geared even faster that that, and it won. so obviously, it will depend on the game, but in my opinion, 14 fps isn't "too fast".
Your robots were certainly zippy! I'd love to know how long it took the robot to get to its terminal velocity (and what that velocity is.) Maybe that would be a good fall project for your software folks graphing speed vs time as measured by an encoder on your 2014 robot.
Going that fast will also impact power consumption during acceleration. I wonder what the peak current is. |
I'm not really sure what you mean by "With frame perimeter rules, are you really gaining extra room this way?" |
#10
I forgot to post the estimated weight. According to inventor, these modules will be over a pound lighter that last year's model: Weighing in at 6 lbs each.
Including all that is pictured except the bumper, the drive base should weigh about 30.5 lbs. |
#12
Absolute encoder. TT electronics 6127 series. .25 to 4.75 volt output. more like 11$ a piece. Used on our swerve for 3 years now. Like them.
#13
Yeah, we've used those encoders sense champs this year. |
#14
Thanks, what's the rotate over point look like? Just a transition from high voltage to low? Can I simply map 0-360 to .25-4.75 and call it a day?
#15
You can also get the flattened shaft version, so that set screws won't slip. |
