Go to Post Am I just a freak? - Josh Hambright [more]
Unread 18-08-2014, 22:47
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: 6-sided tank drive
Originally Posted by evanperryg View Post
If I may ask, why are your angles "149.07 degrees" and "105.46"? You will never ever need that kind of precision in a FRC situation, especially on a frame which will be bashed and smashed into every 6 seconds anyways.*
Even with a chopsaw/bandsaw/mill/cnc mill/whatever, it is certainly a better real world design if you round those off to some amount. How critically important is it that you are exactly perfect? In your robot's frame, just about never.
Also, just a recommendation, While it is less pretty, using 1/32" (or preferably 1/16" or 1/8") increments instead of decimals is much less of a hassle for whoever will measure the parts, and just a couple clicks in CAD
Not trying to be a wet blanket on this design, it certainly is cool, but it would be beneficial for every party involved if you simply rounded to the most convenient dimensions, where there will be an immeasurable difference in performance, but a significant improvement in both engineering design quality, and manufacturing
*after all, the entire point of a 6 sided drive like this is for the very purpose of escaping trapping t-bones"
