19-08-2014, 07:13
IT'S THE BUMP N' DUMP
AKA: Evan Grove
 FRC #4536 (The Minutebots)
Re: pic: 6-sided tank drive
Originally Posted by BBray_T1296
If I may ask, why are your angles "149.07 degrees" and "105.46"? You will never ever need that kind of precision in a FRC situation, especially on a frame which will be bashed and smashed into every 6 seconds anyways.*
Even with a chopsaw/bandsaw/mill/cnc mill/whatever, it is certainly a better real world design if you round those off to some amount. How critically important is it that you are exactly perfect? In your robot's frame, just about never.
Also, just a recommendation, While it is less pretty, using 1/32" (or preferably 1/16" or 1/8") increments instead of decimals is much less of a hassle for whoever will measure the parts, and just a couple clicks in CAD
Not trying to be a wet blanket on this design, it certainly is cool, but it would be beneficial for every party involved if you simply rounded to the most convenient dimensions, where there will be an immeasurable difference in performance, but a significant improvement in both engineering design quality, and manufacturing
*after all, the entire point of a 6 sided drive like this is for the very purpose of escaping trapping t-bones"
The weird angles are the result of the not-weird side lengths. The tolerance should be pretty high.
Oh, and it's welded 1/8" aluminum tubing
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013 Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015 Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
