Go to Post Blue Nitrile Tread is the best smelling wheel tread. #thingsyoufigureoutat2AM - Ginger Power [more]
Unread 19-08-2014, 13:30
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: 6 CIM swerve CAD from 2471
Originally Posted by BBray_T1296 View Post
It is hard to see, but I am concerned that the belt may get caught between the gear and the middle CIM pinion and get chewed up. Is there a flange on the underside of those pulleys? or is there some other way to insure the belt does not ride a little too low?
You're concern is warranted, and in the CAD there are some washers that hang over either side of those pulleys to keep the belt in place. Although, I'll admit that if I were to try and build this design, I would replace all those pulleys with fanged versions. I CADed this in a very short amount of time, when I didn't have good internet access, so I used pulleys that T already had CAD for.
Assuming that the robots center of rotation is somewhere along its mid plane. (I've found a reason of it to be anywhere else) Then a robot with this drive base would be able to translate without any skidding, or rotate without any skidding, but it would have a limited amount of skidding when rotating and translating at the same time. I say "limited", because the module is only 20" long and the other side length of the robot would most likely be about 35".
FLL Team Future imagineers
FRC Team Mean Machine
