Go to Post I think that's what they think you will think, therefore you are thinking what they want you to think. - Wetzel [more]
Unread 20-08-2014, 12:21
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
pic: Chassis Concept
Unread 20-08-2014, 12:22
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Re: pic: Chassis Concept
Are the outer wheels powered? If so, by what?
Very clever gearbox integration into the drive base, certainly a space saver.
Unread 20-08-2014, 12:34
Excellence is Bliss
FRC #0111 (WildStang)
You're losing strength in your chassis when you split that top flange on the inside into two separate flanges to make room for that motor. I'd flip the inner flanges in the opposite direction and raise the height of the inner drive plates if possible to make a continuous S bend instead of a C.
Unread 20-08-2014, 12:44
Front and rear wheels are chain driven. Just not shown.
Inner rail design is the same as AM14U am-2567 inside KoP chassis plate.
Unread 20-08-2014, 13:02
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
I like it! Rigid, cheap, low COG, and it fixes one of the biggest problems of the otherwise-awesome AM14U - the outer plates are fixed directly to the front and back plates. How are you joining the inner plates to the front and back?
Unread 20-08-2014, 13:18
A 3" 1/4-20 from outside rail through 2.125 side rail connector into front rail (same as this years chassis). Bumper mount rail is offset and pocketed to clear socket head. No exposed fasters
Unread 20-08-2014, 13:26
AKA: Brendan Simons
FRC #5406 (Celt-X)
OK, if I'm understanding correctly, the front and back rails are split into 3 pieces with the 1/4-20 bolts passing through the outer rail, spacer and inner rail before anchoring in the front/back rail. I'm guessing the spacers are made from front-rail pieces, with the holes drilled out.
It would be stronger if the front and back rails were one piece. I've often thought AndyMark should have made the front/back rails screw into the side rails, and not vice-versa. Nevertheless, your design will work fine I think, and I like that most of it is COTS parts, which will reduce cost, schedule and design risks. Good luck!
Unread 20-08-2014, 13:28
Bryce Paputa's Avatar
FF TSL: Frog Farce
FRC #0503 (Frog Force)
What do the green pneumatic cylinders do? Lift it on ball casters?
Unread 20-08-2014, 13:29
AKA: Brendan Simons
FRC #5406 (Celt-X)
You should also think about how the belly pan connects to the side rails. It would be strongest if it could cross brace both the inner and outer side rails to the front and back, but that will make it a little harder to service. Another option is to add more of your spacers between the inner and outer side-plates (like the original AM14U churros, but with more vertical strength)
Unread 20-08-2014, 13:55
As with many concepts posted on CD, not all of details are shown like reinforcement plates for the corners, spacers between the rails, the belly pan attachment scheme, adjustable rocker design for end wheels, axle attachment system to rails, all of which are carry over from our 2014 chassis.
Bimba FS-090.75-CFT cylinder paired with ball caster
http://www.essentracomponents.com/sku/ACC-1072
Unread 20-08-2014, 14:02
Oblarg Oblarg is offline
AKA: Eli Barnett
I like this a lot. Very clever gearboxes - do they use only bearing holes that are already present, or do have to do some machining yourself? If the latter, is there any reason for using the AM14U plates instead of designing it from scratch?
Edit: After writing this post I noticed the shifter cylinders - it's kinda hard to see the gearboxes in this pic. Could you show us some pics from other angles for a better look?
"The breakfast of champions!"
Unread 20-08-2014, 17:53
Excellence is Bliss
Okay, that makes sense then. Sorry, I didn't notice that at first.
Unread 22-08-2014, 14:22
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
Always love the gear box integration with the frame rails. I would highly recommend looking into 2337's CAD as they have been doing this for a couple years; although they have not yet used ball casters....hint hint clint
