Go to Post Okay, okay, I'll bring your Krispy Kremes to the Championships ... I bought them right after the '03 Championships ... I'm sure they are still in the attic - Natchez [more]
Unread 20-08-2014, 17:03
Joining the 900 Meme Team
FRC #0079
Re: pic: New swerve CAD from 2471
Originally Posted by Gdeaver View Post
Absolute encoder. TT electronics 6127 series. .25 to 4.75 volt output. more like 11$ a piece. Used on our swerve for 3 years now. Like them.
Thanks, what's the rotate over point look like? Just a transition from high voltage to low? Can I simply map 0-360 to .25-4.75 and call it a day?
Unread 20-08-2014, 17:07
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Yes, you can then call it a day. It's really simple to code, and we've found that the end behavior is surprisingly linear.
You can also get the flattened shaft version, so that set screws won't slip.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 20-08-2014, 17:08
FRC #0079
Thank you, just saved me a a fair bit of money in encoders.
Unread 21-08-2014, 13:01
seanthompson seanthompson is offline
FRC #0537 (Chargers)
seanthompson is an unknown quantity at this point
Can you post the link to the encoders please?
Unread 21-08-2014, 21:43
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
my guess is they are talking about this part:
http://octopart.com/6127v1a360l.5fs-...ogies-19910150
There are a number of different options it can be ordered in, see data sheet
Note these are rated at 500 RPM in the datasheet. So they likely more than sufficient for monitoring the position of a part - like the wheel's heading in this case. Without proper gearing they are likely not a good choice for use on things like a shooter wheel. If you're looking to monitor wheel rate of travel over ground, these aren't appropriate unless you've got wheels bigger than 6" or have geared the encoder down (assuming you're targeting a top speed or around 14fps).
http://team2168.org
Unread 21-08-2014, 21:47
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
Plus it's an analog output so in a high RPM application you'd be monitoring a saw tooth signal on the analog port.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 03-11-2014, 20:15
aaron_ aaron_ is offline
Junior Member
aaron_ is on a distinguished road
Looks very cool! And yes, I assume they are using this part http://componentsearch.com/search/se...127V1A360L.5FS
