Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 25-02-2003, 13:32
D.J. Fluck
Originally posted by LizJJury
if it is used to move then won't there be a problem with the tiny wheel thingy's going past the mesh on the ramp???? I hope not cause that is not good and will get you disqualified. unless you just made that so that it looks pretty and keeps the chain from falling off. anyways......Go Team 902!!!!!!!!!!!!!!
I assure you even with a full 130 pound load, the timing belts or any other part of the robot DO NOT pass through the mesh
