Go to Post You don't have enough money, you're under-staffed, you're not quite sure what the customer wants, requirements change, and they want it yesterday. - Kimmeh [more]
Unread 26-08-2014, 17:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: 303 Prototype Sheet Metal Drivebase
Why do you want to have a gear powertrain? Saying that 341 and 25 have them is not a sufficient answer. What advantages does it you? What issues with other powertrain solutions you've used does it solve?
Make all of your idler gears dead axles that double as standoffs. It makes your frame much, much more rigid, saves a little weight, and is generally a "free" way to add rigidity.
Not to mention it will save on hex bearings, which are notoriously hard to procure for FRC teams. Based on the picture, it cuts a minimum of 18 hex bearings out of the design, and presumably 36 if you were to use round bearings in their place on the idler gears. Using Vex prices, that would also result in over $120 in savings, as well.
