Go to Post Rules can be rewritten, problems can be fixed, but peoples' feelings are far from inanimate - they need more consideration than just being "corrected". - Eugenia Gabrielov [more]
Unread 28-08-2014, 16:25
Drew4564 Drew4564 is offline
It's Tape Measure Time!
FRC #4564 (Orange Chaos)
Drew4564 is an unknown quantity at this point
Re: pic: Modified AM Shifter Gearboxes
If your looking for something more compact I'd recommend either:
Bimba Flat - 3/4 Bore (due to #10-32 male thread), could do 9/16" bore as well
FO-040.5-MT
or
VEXpro Pancake
You will probably have to modify spacer length as an FYI when switching to a pancake cylinder.
My team will definitely look into these, thanks for your help! The current cylinder is much larger than it needs to be, and would take up a lot of space at the bottom of the drivetrain.
