pic: Modified AM Shifter Gearboxes
Re: pic: Modified AM Shifter Gearboxes
I apologize if I'm missing the obvious, but aside from the gold coloring what modifications have been made to this transmission, and why did you make them?
Appears to be a 1st generation shifter, with its internal double sprocket, with the addition of an external extended output shaft, like a super shifter.
I didn't see the extended shaft on the first time around - thank you for pointing that out.
This looks surprisingly lightweight. Perhaps replacing the cylinder with a smaller one would be good though.
We made them simply for the fact that we had two given to us by a retired team, and it was a much cheaper process than buying new ones. I agree that a smaller piston would be desirable, but I'm not sure what would work as a replacement.
Bimba Flat - 3/4 Bore (due to #10-32 male thread), could do 9/16" bore as well FO-040.5-MT or VEXpro Pancake You will probably have to modify spacer length as an FYI when switching to a pancake cylinder. Last edited by R.C. : 28-08-2014 at 01:12. |
These older gen-1 shifters are almost entirely steel (sideplates, gears, sprocket, shafts, dog, bearings, bolts) so they are actually quite heavy, but they are durable.
#10
I like it as an engineering exercise. Were you planning on using these for next season?
#11
Yes, we are planning on using them for next season, and are currently in the process of building an off-season drive with them! It was a great way to learn Solidworks for my team, as we had to not only modify the gearboxes but put them on a WCD.
#12
To obey fab schedule rules, you will need to disassemble them to their original COTS state, and replace and redo any modified parts.
#14
A separate discussion altogether is, how many teams actually follow that vs teams that don't. |
#15
![]() Still trying to figure out if it's really worth stepping up to FRC..... seems to me like the odds are stacked against 1st, 2nd and maybe even 3rd year teams. |
