Go to Post When's the last time you called up FIRST headquarters just to say thanks? Or saw a volunteer at a regional and said, 'Hey, you're doing a really great job here. Thank you for everything you're doing in your spare time.' - Amanda Morrison [more]
Unread 22-09-2014, 10:33
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: pic: Hex Bearings
The bearings get used on drive trains without that kind of failure. It seem the drive train would have a higher loading. I am a little hesitant to blame this on bearing quality. Maybe the shaft is bending or severely misaligned which is torquing the bearing rather than a axial load?
If you don't know what you should hook up then you should read a data sheet
