Go to Post Let's Just say i am the one that gives Firefighters, paramedics, and law enforcement a job - Tytus Gerrish [more]
Unread 22-09-2014, 16:08
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
Re: paper: Scouting Accuracy Benchmarking Study
This is a great paper, I really enjoyed reading it. In the back of my mind, I have always wanted to run an analysis like this for every team at an event that will give me data, and then give an award to the team with the "best" scouting data using an analysis like this. Of course, thinking grand ideas is far different than implementing them.
The importance of good scouts too often seems undervalued relative to other team positions, and I think that giving a small team award could go a long way toward making scouts have a more enjoyable experience.
Unread 22-09-2014, 17:09
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Hmm, was hoping for a more complete data set to try and grade the accuracy of OPR for 2014. Still a nice paper, and an interesting first look at accuracy in scouting.
Unread 22-09-2014, 18:58
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
The sample size may be small, but did you find a correlation between amount of data taken and accuracy? (My personal opinion/assumption is that teams generally take way too much data which makes it harder to scout, hurting the data teams actually use).
Unread 22-09-2014, 19:48
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
I tried to do a project like this back in 2012 using data from 2010-2012 (I used 2337's datasets for this period, 2-3 events per year). While this was somewhat useful in comparing the utility of OPR across different years, I ran into difficulty comparing OPRs directly to scouting data because extrapolating scores from teams' statistics is a nontrivial task. OPRs are, of course, dependent directly on match scores, so this extrapolation is necessary for comparison. For example, in 2011, tube scoring did not scale linearly. You'd encounter the same problem in 2014 with scores of balls depending on the number of assists. However, it's definitely a topic worthy of further study.
Interesting question! This isn't something I originally considered, but I took a look. With only 5 data points, 4 of which are pretty similar in accuracy, I wasn't optimistic about having a real answer here, but then it got worse. All 5 teams took around the same amount of data! They varied from 16 fields of data to 21. None had exactly the same number, and the most accurate team was in the middle at 18 fields.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
