Go to Post Hack saws are for hack work, the kind we don't do. - sanddrag [more]
Unread 04-10-2014, 23:02
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: paper: Belt Driven VersaChassis WCD - Step by Step guide
Originally Posted by Mike Marandola View Post
Thanks. This is really useful. Does anyone have any experience using the 2 CIM ballshifters with the Versachassis?
We use the 2 cim ball shifters. It was mounted on the top channel. It drives the center wheel with a 15mm belt. The outboard wheels are driven by the center wheel with 7mm belts.
If you don't know what you should hook up then you should read a data sheet
