07-10-2014, 16:47
Re: paper: Belt Driven VersaChassis WCD - Step by Step guide
Originally Posted by Oblarg
As for why bother with 9mm, it allows one to use the WCP gearboxes with pulleys-in-gearbox just as one would do with chain. Personally, I'm not a huge fan of that setup - if a belt does break (admittedly unlikely but it's better not to tempt Murphy if you can avoid it) it's a royal pain to fix - but even in other setups it's nice and much more compact to be able to fit 2 9mm belts on one pulley than have two pulleys.
Making your own pulleys from stock is pretty easy, and buying bigger spacers for a gearbox is even easier!
