Go to Post i openly welcome our large game piece overlords - Chexposito [more]
Unread 07-10-2014, 20:09
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
Re: paper: Belt Driven VersaChassis WCD - Step by Step guide
Originally Posted by Oblarg View Post
There is a reason not to have one, in that they cost money and can be safely skipped provided you have some other way of keeping the block from sliding.
The easiest way to do this is to simply assemble the thing without the cam, pull the versa-block until the belt is properly-tensioned, and then match-drill from one of the holes in the versa-block through the framing member and bolt it in place. You will then never have to worry about belt-tension again, and can save money on the cams. We did this last year at 449, and it worked perfectly. If your pulley is too close to the framing member to fit a nut on the other side of the versa-block, you can even tap one of the holes and just screw it into the versa-block itself.
I would not recommend doing this with chain.
We have play with the belt tension both by manually pulling the block and using the cam. We find the cam allow us more fine adjustment. To us the cam is a little extra "inconvenience" that we can live with.
