Go to Post Spread inspiration; Don't destroy it. - IntensifiedAmp [more]
Unread 09-10-2014, 01:26
JackFisher's Avatar
JackFisher JackFisher is offline
JackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud of
Re: pic: Hex Bearings
Originally Posted by FrankJ View Post
The bearings get used on drive trains without that kind of failure. It seem the drive train would have a higher loading. I am a little hesitant to blame this on bearing quality. Maybe the shaft is bending or severely misaligned which is torquing the bearing rather than a axial load?
On our drive trains, we have shattered these hex bearings two seasons in a row. Its great that vex has a redesigned option now. The part of the bearing that failed on our drives was the corner where the steel was a bit thin due to the hex.
