Re: pic: Tiki Tech Transmission
Very cool. Is this a 2 cim or 3 cim setup? What is the weight?
Also, you mention that this is for WCD. Are the sprockets inside the gearbox or designed to be outside? If it's the latter, I suggest changing it to the former so that the gearbox is easier to mount. |
The weight with mini and full size CIM is 14.7lbs including the encoder ![]() |
But that's just like, my opinion man. Really like some of the design that went into this (and the full chassis CAD)-- the motor controller mount between the gearbox is cool, and I like how your motors match the angle of your frame on the sides. There are a lot of cool elements here and I hope you guys can capitalize on what you learn with this offseason drive to make a killer drive train in the 2015 season! |
What is the idea behind having three stages? The way i see it you could probably do the same thing you have there with only two axles making it a bit lighter.
For your drive purposes, I highly recommend that you just design a 4 cim gearbox. Or, better yet, decrease to 3 cims.
Also, instead of using gears to combine the motor output, I would take a look at 192's design which uses belts for the first stage of transmission. You can combine the outputs of all the cims for a lot less weight that way instead of using gears. Then just use the shifting stage to shift between a 14:40 and a 34:60 stage (both of those shifting gears are sold by WCP) to get the last transmission stage. |
Bleh yes. Sorry, I was thinking of the ball shifting gears for the primary, and the dog shifting for the secondary.
You are making a drivetrain that is 58.8lbs *without* the frame? Are you making the rest of your bot out of carbon fiber?
#10
And mechanisms to run on hope and dreams while drawing that much power for that drive train...phew
#11
Ok my bad. I am new to the iProperties thing. This should have been caught by me, knowing that the CIMs together weigh about 5lbs. There is no way that transmission weighs 9 lbs!!! More like 3. The transmission is basically a hybrid of a WCP 2 CIM DS, 2.15lbs. and 3 CIM DS, 3.5lbs. Weight will be between that since it is basically a stretched DS if you will. A 2CIM DS with one extra idler. We went with an idler gear instead of belts. Much easier for us, we had it on hand. The entire transmission was designed using the existing gears from our 3CIM DS making it easy to test by just replacing the frames. Future orders of different gear ratios from WCP will just work. Last year we used the WCP 3CIM DS and are extremely happy with it. Never had any issues with breakers tripping on our 6 wheel WCD, but space was tight. We wanted a stretched 2 CIM DS, if you will. That was set up for in-frame chain setup and over the frame motor orientation. (see hex frame). Being able to orientate the motors in either direction and a quick and easy encoder placement was the goal. Our competition bots have always had a post tapped into the front or rear axle that the encoder used. Not always pretty.. Something different for us.. |
#12
-Ronnie |
#13
As a team with limited machining tools available and even more limited machine shops. Well ok, no real machine shop on the island... It was a great way for us to move to a more competitive drivetrain. I would recommend these transmissions as an easily incorporated subsystem. We ran 5.5/15fps and never tripped the breaker, didn't even get warm.. Originally we ran the Versa wheels, but they couldn't handle. http://www.chiefdelphi.com/media/photos/40426 This is what happened to our tires in our first practice match. The robot ran into the wall during autonomous and drove constantly in low gear. Luckily they were not too expensive.. Changed to Colson at worlds, not going back. In fact our new Colson wheels arrived last week! The power was great! First time running a shifter and the shifting never failed. If our CNC doesn't arrive we would use them again, if it works with the new game.. Our poor CNC It is on a boat, sailing 1000's of miles to us. Hope that hurricane last week doesn't add another month or so. The 3 CIM DS has a fairly large footprint. It is why we are toying with the motors over the frame. (New rendition is a one piece 4 motor with the pneumatic shifter under the motors) Hope this helps. Aloha! |
#14
-Ronnie |
