Re: pic: Tiki Tech Transmission
But that's just like, my opinion man. Really like some of the design that went into this (and the full chassis CAD)-- the motor controller mount between the gearbox is cool, and I like how your motors match the angle of your frame on the sides. There are a lot of cool elements here and I hope you guys can capitalize on what you learn with this offseason drive to make a killer drive train in the 2015 season! |
What is the idea behind having three stages? The way i see it you could probably do the same thing you have there with only two axles making it a bit lighter.
For your drive purposes, I highly recommend that you just design a 4 cim gearbox. Or, better yet, decrease to 3 cims.
Also, instead of using gears to combine the motor output, I would take a look at 192's design which uses belts for the first stage of transmission. You can combine the outputs of all the cims for a lot less weight that way instead of using gears. Then just use the shifting stage to shift between a 14:40 and a 34:60 stage (both of those shifting gears are sold by WCP) to get the last transmission stage. |
Bleh yes. Sorry, I was thinking of the ball shifting gears for the primary, and the dog shifting for the secondary.
