Go to Post Compact gearboxes are a wonderful thing. - Cothron Theiss [more]
Unread 15-10-2014, 22:45
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
Re: pic: Tiki Tech Transmission
Originally Posted by Gregor View Post
I would not feel comfortable putting half the weight of my robot into gearboxes. This is even ignoring the breaker issues of an 8 motor high traction drive.
Agreed. It looks like a very nice gearbox, however. Especially with your drive setup, which looks like an 8WD with some nice elements (chain in tube, 6-sides), I'd reevaluate whether the best use of your resources is four independent, custom gearboxes. Regardless of whether you want to do 8-motor drive, the redundancy in weight running four gearboxes seems like an exceedingly problematic limiting factor when considering the rest of your robot.
But that's just like, my opinion man.
Really like some of the design that went into this (and the full chassis CAD)-- the motor controller mount between the gearbox is cool, and I like how your motors match the angle of your frame on the sides. There are a lot of cool elements here and I hope you guys can capitalize on what you learn with this offseason drive to make a killer drive train in the 2015 season!
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
Unread 15-10-2014, 23:09
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Henrique Schmit is an unknown quantity at this point
What is the idea behind having three stages? The way i see it you could probably do the same thing you have there with only two axles making it a bit lighter.
Ready for the water games
http://i.imgur.com/QQXtifE.jpg
Unread 16-10-2014, 00:28
For your drive purposes, I highly recommend that you just design a 4 cim gearbox. Or, better yet, decrease to 3 cims.
Also, instead of using gears to combine the motor output, I would take a look at 192's design which uses belts for the first stage of transmission. You can combine the outputs of all the cims for a lot less weight that way instead of using gears. Then just use the shifting stage to shift between a 14:40 and a 34:60 stage (both of those shifting gears are sold by WCP) to get the last transmission stage.
Unread 16-10-2014, 00:38
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Did you mean 14:60 and 34:40?
R.C.
MadTown Robotics Team 1323
Unread 16-10-2014, 01:12
Bleh yes. Sorry, I was thinking of the ball shifting gears for the primary, and the dog shifting for the secondary.
