Go to Post words of advice: never tease your dad about his receding hair line. it will come back to haunt you. trust me. - Brandon Martus [more]
Unread 16-10-2014, 00:28
Re: pic: Tiki Tech Transmission
For your drive purposes, I highly recommend that you just design a 4 cim gearbox. Or, better yet, decrease to 3 cims.
Also, instead of using gears to combine the motor output, I would take a look at 192's design which uses belts for the first stage of transmission. You can combine the outputs of all the cims for a lot less weight that way instead of using gears. Then just use the shifting stage to shift between a 14:40 and a 34:60 stage (both of those shifting gears are sold by WCP) to get the last transmission stage.
Unread 16-10-2014, 00:38
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Did you mean 14:60 and 34:40?
R.C.
MadTown Robotics Team 1323
Unread 16-10-2014, 01:12
Bleh yes. Sorry, I was thinking of the ball shifting gears for the primary, and the dog shifting for the secondary.
