Go to Post Sometimes, having someone that can teach you just shows you another way to do what you've been doing, but in fewer moves. - Amanda Morrison [more]
Unread 16-10-2014, 15:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Mechanical limit switches - acceptable practice?
Originally Posted by bmammen View Post
lets go with the switch was physically damaged during a match (and it was), so we can leave programming out of the discussion for right now
Do you know with acceptable certainty why the switch got damaged? I ask because in your original post it sounded like you don't know why:
two instances where our software controlled limit switch either didn’t work or was physically knocked off center
Before you fix something, it's worthwhile to make a concerted effort to figure out why it failed. Software could be the cause. Or lack of a flexible extension on the actuation lever. Or improper mounting of the switch.
