Go to Post Sorry for the profanity but how about mentioning the "C" word? Commercials? - Pavan Dave [more]
Unread 25-10-2014, 21:04
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
Re: pic: Offseason 8W Tank Drive
Seems like it would be tough to work with in the pit if it would need to be worked on. I'm basing this by the number of gears.
Can you post some specs?
looks cool!
Unread 25-10-2014, 21:43
Knufire Knufire is offline
Sure!
The drive channels are two pieces of 1"x3" C-channel, with the two sides connected by a single 0.090" bent sheet metal piece. You could also replace this bent sheet metal piece with the front/back rails of the 2014 VEXPro Drive in a Day or the 2015 kitbot end rails (at least as much as I can tell from the drawings).
The gearbox is mostly just a repackaged Ball Shifter. The only trick is that two of the CIMs are on a separate first stage reduction and then connected to the rest of the gearbox with a 9mm HTD belt. These then drive 8 4" Colsons on dead axles.
Here are the drive numbers:
Weight seems to be about ~40 lbs, including motors and chains.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 25-10-2014, 21:46
Oblarg Oblarg is offline
AKA: Eli Barnett
What program are you using for those drive numbers? AFAIK, it's pretty much impossible to pull 90 amps per CIM on a 6CIM drive under any circumstance with the batteries we use in FRC.
"The breakfast of champions!"
Unread 25-10-2014, 21:53
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
The visual style looks different, but it is just like JVN's Calculator
Unread 25-10-2014, 22:00
It's the updated version of JVN's calculator:
http://www.chiefdelphi.com/media/papers/2755
Unread 25-10-2014, 22:02
I am Dave! Yognaut
AKA: Brian Bray
Ah, ok. I guess he decided to scrap the florescent colors for something more soothing
Unread 25-10-2014, 21:57
Jared's Avatar
Jared Jared is offline
He's using JVN's design calculator. It just calculates out how much torque you'd need to slip the wheels with the gear reduction, then, from the motor curve, it figures out the current draw per motor. For high gear, voltage drop will play a huge role, and I don't think he'd be able to get the wheels to slip at all. The current/motor number is more important in low gear.
FWIW, we found that the 1.3 CoF was a little on the high side for normal traction wheels.
Unread 25-10-2014, 22:05
AKA: Eli Barnett
Thanks. Not taking battery voltage drop into account would explain that pretty well.
I know the calculator on the WCP website does take battery voltage drop into account, which is nice, but their "max pushing force" calculation uses the static COF even for a traction-limited drive, which is not-so-nice.
Unread 27-10-2014, 16:05
Michael Hill's Avatar
Try my calculator out.
http://www.chiefdelphi.com/media/papers/3038
Unread 30-10-2014, 10:38
A quick question, the sheet piece as shown is made out of 0.090" Al 5052-H32. I know other teams, such as 33 and 67, have had success with thinner sheets. Would trimming down to 0.063" be a wise decision?
Unread 30-10-2014, 17:21
You can go even thinner. We're experimenting with 0.050" 2024-T3 this offseason, and it should actually be stronger than .090" 5052-H32. We get this added strength by not drilling lightening holes. Your robot is really only as strong as the smallest cross-sectional area (in tension and compression). So by eliminating lightening holes, the smallest cross-sectional area ends up where the axle holes are. It ends up almost the same weight, but almost twice as strong (ballparking, of course).
Unread 30-10-2014, 20:46
asid61 asid61 is online now
Is 2024 easy to bend?
Unread 30-10-2014, 21:18
Angry Re: pic: Offseason 8W Tank Drive
We use a 0.125" bend radius. It's a bit tighter than aviation requires, but it's good enough for FRC, especially if you bend against the grain. We've reached the limit of our brake, but fortunately it's big enough for a robot.
Unread 30-10-2014, 23:44
Oh, very good then. I was worried the stiffness would make the bend radius unusable. I'll have to ask our sheet metal guy if he can do 2024.
Unread 03-11-2014, 02:18
Here's the current revision of the drive. The only main differences are the lightened bellypan and less aggressive pocketing on the front/back rail. Any last tips? I've debated elongating the top end rail flanges and possibly putting another flange down the back as 971 does.
Another change (not shown) is changing the outer gearbox bearings from round to hex. This allows the intermediate shafts to be pulled out without having to disassemble the outer drive rail.
