Go to Post Doing something reliably is better than doing something well occasionally. - Andrew Schreiber [more]
Unread 10-27-2014, 02:35 AM
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Re: pic: VR-001: A Jersey Voltage Simple Hex Frame
Originally Posted by Oblarg View Post
You can do that, but then they come all the way out of the bearing blocks (and ostensibly any sprockets you have on the other side are then loose, too).
Not saying you should change your design; it's a minor concern. It's just that I've spent a lot of time servicing drives, and little details like this are worth thinking about, if nothing else.
Cool, that certainly would be harder to break.
Correct, Service of drives are definitely a pain. We got to the point this year where we could have our entire drive train dismantled (gearboxes off, axles off, bearing blocks out, belts off, sprockets off, motors unplugged) and back together again in less than the time it takes for us to be back to the field for our next elimination match, so about 12 or so minutes. We train our pit crew well and teach them that there are definitely trade-offs to running the type of setups we run. We do however consider all options prior to final design.
