Go to Post i have a feeling that the field with be the same as it was last year just to save some money. but what is inside the the field will be diferent. - Michael Leicht [more]
Unread 28-10-2014, 13:06
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
pic: 319 Octagonal Drive Isometric
Unread 28-10-2014, 13:10
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Re: pic: 319 Octagonal Drive Isometric
Looks awesome, but is the wheel cutout in the bellypan big enough to take the wheels out without taking the shaft and chain off? Then again you won't be swapping out colsons much, if at all.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 28-10-2014, 13:22
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
We are doing something just like this, it looks scary similar haha.
Unread 28-10-2014, 13:23
Are you worried about something coming under your bumpers and hitting the chain/sprocket?
Also, it seems like the 2nd frame is a LOT just to support the bumpers.
Assuming similar bumper rules as previous, something inplane with the existing drive frame could support it for far less pieces/weight/fab.
Unread 28-10-2014, 13:27
RonnieS's Avatar
AKA: Ronnie Sherrer
We adjusted our brackets to make sure our bumper was low enough to not have that problem.
I am think that structure is supported so well for the possibility of that being a second tier and not just bumper mounts.
Unread 28-10-2014, 13:28
Why have a 2nd tier? The superstructure can mount to the drive frame.
Unread 28-10-2014, 13:29
RonnieS's Avatar
AKA: Ronnie Sherrer
Maybe wanting to get something like an intake as far out $@#$@#$@# possible?
Unread 28-10-2014, 14:35
Robotics Engineer
Those outer sprockets are my biggest concern with this design. I'm considering taking the hit on wheelbase to extend the front and rear frame members.
I put the second frame that high so that it was supporting the middle of the bumpers. Since the bumpers are as low as possible, I was worried about the moment created when running into a robot with the bumpers in the higher end of the bumper zone.
Unread 28-10-2014, 14:44
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
This strikes me as a prime candidate for belt/chain in tube, in order to protect the chain. It also means the cantilever lever arm on the middle wheel won't be as long.
Unread 28-10-2014, 15:39
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
If you do a one piece bumper with the corners well joined, then the moments should be resolved through the bumper wood and transformed into lateral and vertical forces at the frame. We run a very low frame with a one piece bumper that has held up really well (the top of our frame is about 3.5in above the ground).
Unread 28-10-2014, 15:47
Robotics Engineer
Excellent. I actually mocked up some bumpers very similar to 971's this year after perusing through your Picasa album.
Unread 28-10-2014, 15:58
Our cad should be pretty representitive our our bumpers also. We added corner gussets for our 2014 bumpers and found them well worth the added effort. (The 2014 bumpers held up much better than 2013).
Unread 28-10-2014, 16:35
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
This isn't really a specific question for the drivetrain, but I've been working with the same gearboxes and I was wondering how you are supposed to mount them. Do you just use the bolts from the standoffs in the gearbox?
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 28-10-2014, 16:46
Robotics Engineer
It depends on how you intend to use them. Are you using them for a WCD?
Unread 28-10-2014, 16:55
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Octagonal Drivetrain! Its been a long time since I've seen a good picture of one.
179 did it ?first? in 2005. (Wow I'm surprised I commented on that one too). It was a pretty great robot too. Remember, that was 2005 BB (Before Bumpers Era).
A couple things I'd recommend:
  • Studying some match footage to see if it really makes a difference on a T-Bone Pin. (You don't need to go back to 2005 for this)
  • Do some math proving that this concept could work in the world of T-Bone Pins.
  • Will this make a difference on turning?
I'm not convinced it will make a significant/reasonable difference in any scenario, but all I got is anecdotal stuff.
