Go to Post Don’t let the medals you win and the trophies on your mantel define who you are. Let it be the lives you’ve touched and the legacy you leave behind. - Sean Schuff [more]
Unread 30-10-2014, 01:17
philso philso is offline
FRC #2587
Re: pic: Concept 6W Drive Train
You may want to consider what would happen if this chassis is used in a game that allowed high speed and hard hitting, like this years. There is the possibility that the vertical angle pieces in the corners deform when hit on that corner causing the two outermost side tubes to move backward. Since it looks like your axles are supported by the lower side tube, they may bind in the bearing blocks and/or cause the robot to not drive straight.
