Go to Post Yes, the real world is like that. Let's operate on a higher plane. - Taylor [more]
Unread 30-10-2014, 09:44
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: pic: FRC558's modified VEXpro Drive in a Day
Originally Posted by TD78 View Post
I should clarify. I was not looking to form 3/8"-16 threads (or similar) using a die...I was thinking about drilling and tapping the ends of the steel rod (using a drill and tap). The rod would become a stiffening dead axle.
You could turn down the ends of the 3/8" rod and thread them for 1/4-20. The major downside of this being that you'd need to remove the outside of the drivetrain if you wanted to change a wheel.
Unread 30-10-2014, 09:45
I should clarify. I was not looking to form 3/8"-16 threads (or similar) using a die...I was thinking about drilling and tapping the ends of the steel rod (using a drill and tap). The rod would become a stiffening dead axle (although you don't advocate that practice).
Ah, I see. If you mount through the bolt rather than the axle (i.e. the mount hole is 1/4" rather than 3/8" and the 3/8" axle is the stiffening rod) then I don't know if there would be axial load on the bearings.
I would worry about the 1/4" bolt elongating the mount holes after a rare hit - like one that tips the bot up a bit, then the bot slams back to the floor, or like what happens when coming down off of a ramp/bump. We experienced some of this in 2007. When we went back to this style of dead axle in 2011, we used 3/8" rods and also used 1" angle brackets (1/8" thickness) to mount the wheels below the 1x1 frame. This gave us flexibility to change a mount out if we had problems. The "look" of the drive train where we mounted the wheels was similar to the old IFI KOP frame rails.
Unread 30-10-2014, 09:51
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Thanks for the feedback, feel free to keep the questions coming. FRC558 was extremely happy with our drivetrain's performance and reliability in the 2014 season. There is something to be said for being able to assemble during week 2-3 of build and not have to touch the drivetrain for 100+ machines.
Anyone have thoughts on using 3/8" steel rod as dead axles? Tap both ends of the axle and it'd be close to using tube axle/bolt. I wouldn't think a 1/4"-20 bolt would work...not enough thickness left in the rod. Something smaller like a #10 or #8...at which point you would have to drill all 4 holes in the DIAD sideplate, rather than using the pre-punched 1/4" hole for the outer wheels (of the 8wd)...but it could work.
I've looked into this, and would likely pursue it if we had the internal resources to machine them. At this time it would require relying on our mentors and sponsors to do work outside of the teams shop.
Did you guys slit the colson wheels at all? Or run them stock?
We run them totally stock, I don't believe the benefit is worth the extra work, however if we need more traction we'll look into it. We have never wanted more traction.
You can use the 1/2" I'D x 7/8" OD bearings as well. Allowing teams to use tube axle.
RC, have these bearings been tested for load? I'd love to run these but I have concerns about testing new things in our drives. If these are more then capable, we'll switch over to them and the tube axle material for 2015.
Unread 30-10-2014, 11:08
puneeth.meruva puneeth.meruva is offline
MIT Class of 2019
AKA: Puneeth Meruva
FRC #1501 (Team T.H.R.U.S.T)
puneeth.meruva will become famous soon enoughpuneeth.meruva will become famous soon enough
do you guys think that there's any chance that FIRST will move back to a max of 4 CIMs instead of 6 CIMs?
Unread 30-10-2014, 11:26
It's a possibility. Or some rule limiting max power in drive.
Unread 30-10-2014, 13:56
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
We can only hope! With the introduction of so many powerful motors available, it's simply lead to a drivetrain power "arms race".
- Mr. Van
Unread 30-10-2014, 15:31
Andrew Lawrence
- Mr. Van
To a point. For the majority of games, what matters most is what's on top of the drivetrain, and how it's used.
Unread 30-10-2014, 15:37
The current level of power allows a team to get going faster, in less distance.
With E= 1/2mv^2, this leads to substantial increase in energy storage in the average FRC robot.
These hits add up over time, and don't really add value to the game.
I would MUCH rather see a drivetrain power limit than a "rough play" rule... The line in the sand the rough play rule introduced was a real bummer.
Unread 30-10-2014, 20:58
Oblarg Oblarg is offline
AKA: Eli Barnett
6-CIM drives aren't only useful for big hits. The added speed is extremely useful for all sorts of defense.
Our drive strategy last year depended almost entirely on positioning - we had to stay between the opposing robot and where they wanted to go. A little extra agility makes that a lot easier to do. It came with definite tradeoffs, and was not an obvious design choice to make, but in the right situation it was very useful, and not just in a "ROBOT ANGRY, ROBOT SMASH" capacity.
I mean, I wouldn't blame FRC for reducing the motor budget, because there was a lot of damage last year, as many teams were not particularly thoughtful in their willingness to smash into other teams' mechanisms. That said, I don't think it can really be argued that it added nothing to the game, and I wouldn't mind the drive power staying where it is, either. I don't think it was game-breaking.
Full disclosure: I believe we played entirely reasonable (but certainly stiff) defense at the DC regional. At the end of that competition, we discovered a sizeable (but not functionally-damaging) dent in one of our AM14U end-plates. So, yeah, it certainly was rough, but I don't think it was anything I'd be unwilling to deal with in future years. I don't believe we caused any non-superficial damage to another robot at any of our competitions.
Edit: Completely agree that the "rough play rule," as it was worded, was awful. I do think it could be done better than that, though.
"The breakfast of champions!"
Unread 30-10-2014, 22:11
Originally Posted by Oblarg View Post
I don't know what it "added to the game" for any team on the receiving end. It's the ignorance that makes me hope the GDC changes something.
Unread 30-10-2014, 22:16
AKA: Eli Barnett
By that logic, anything that changes the game in favor of defense ought to be removed, because clearly it doesn't "add to the game" for the robots trying to play offense.
Unread 30-10-2014, 22:22
Sorry, should have specified it was directed at your glorification of linebacker-style hits.
Unread 30-10-2014, 22:23
AKA: Eli Barnett
Where did I glorify linebacker-style hits? I explicitly stated that we avoided them last year, and my entire post was about the value of a 6-CIM drive in contexts other than forceful collisions.
Unread 30-10-2014, 22:30
Damage to your own robot, stating 6 CIMs are useful for hits and other things, saying 6 CIM agility plays well into a SMASH (...) strategy, you don't think you did non-superficial damage (pretty rude statement in multiple aspects, IMO).
It's like you state one thing, but the tone of how you word it makes a completely different statement, particularly in context of witnessing 4464 do hit, after hit, after hit, after hit in DC. All in the name of supposed "positioning".
Unread 30-10-2014, 22:39
AKA: Eli Barnett
How is that a rude statement? Could you honestly claim any better than "I don't believe we did any serious damage to other robots" if you were playing any sort of defense this year, unless you specifically went to the pit of every team you faced after every match and checked, and had perfect memory to boot? Robot-to-robot contact of any sort has the potential to cause damage. To pretend this is not the case would be dishonest. Acknowledging this is not rude - to the contrary, I think it'd be rather rude to not hedge my claim in that way.
You are reading what you want to, not what I am saying - I did not say "6 CIM agility plays well into a SMASH strategy." I said that 6-CIM agility allowed us to be successful in a defensive strategy that did not involve serious collisions. "ROBOT ANGRY, ROBOT SMASH" is obvious caricature, and was presented as an example of precisely what we were not doing.
It's like you state one thing, but the tone of how you word it makes a completely different statement, particularly in context of witnessing 4464 do hit, after hit, after hit, after hit in DC. All in the name of supposed "positioning" that you supposedly just can't get with 4 CIMs.
You stated in a previous thread (and I quote) "I don't fault 4464 for its defense this year since it was actually pretty clean relative to other matches I've watched." Where is this "hit after hit after hit" coming from, now? Where were we unreasonable in our defense this year? We made a point of not gaining much speed before contacting other robots this year, both because it was likely to cause damage (to their robot and ours) and because it is not particularly effective defense (unless, of course, you've got no class and are trying to disable the other robot - I think we're all better than that here) - sustained pushing is far more effective for interrupting an opponent's play.
I think you are reading it in a tone you want to read given your experience this year. I am in no way a proponent of NFL linebacker-type play in FRC, nor was my post indicating such.
