Go to Post I was on the same plane as 365 returning from Atlanta to Philadelphia last year. The whole rear half of the plane was neon green. - Lil' Lavery [more]
Unread 02-11-2014, 15:19
Aren_Hill's Avatar
Build Nifty Things
Re: pic: Coaxial Swerve Drive Module with 2-speed Ball Drive and Nitrile Tread
Originally Posted by Bryce2471 View Post
1. It looks like there is no thrust bearing above the vertical miter gear. This is not a big deal by its self, (We used thrust washers last year) but it will increase the speed of deterioration on the gears, and decrease efficiency in that gear-set. It also looks like you're planning on using the VEX Pro aluminum Miter gears. This is also not a big deal, lots of team use them, but I suspect the fact that they are aluminum will increase wear speed. With those two things combined, your drive performance may not suffer, but you will probably find yourselves replacing the miter gears pretty often. What is the process for replacing a miter gear? How long will it take?
VEXpro Bevel gears are 4140 hardened steel not aluminum.
-Aren
A guy who likes robots.
