Re: pic: MOEnarch Swerve Drive
10 - 20 ft/s is a pretty big gap there, Nathan
Sdp pi suggests at least 6 teeth engaged on a pulley for full use of the belt strength, it looks like have sufficient engagement for that belt pitch.
I like how they packaged both motors in the drive module, it looks good. Last edited by Deke : 02-11-2014 at 20:18. Reason: typo |
We can use any size up to 44 teeth, flexibility man. Through our testing and based on the game we will determine our optimal speed.
Is it a fair assumption that you will be using 8 CIM drive with this.
If so, how are you planning to keep from popping your main breaker? Are you using current monitoring to keep yourself in a safe zone? |
I would consider changing the location of your digital encoder for a couple reasons.
First, as you tension the belt by moving your cim, it will change the engagement on the Digital encoder. Secondly, generally speaking those things don't appreciate a lot of side-loading. Third, if your belt slips, your wheel will no longer be aligned with the encoder reading. I'd consider a small lightweight bracket that places it directly over the primary shaft of the module itself, so you'll always know the true position of the module. This also relieves any side-pressure on it, and it can be coupled with something as simple as surgical tubing. It will probably be a wash weight-wise. |
We did consider a bracket like you describe but it was just another part to manufacture and would also put the encoder in a more vulnerable location. If there is some unforeseen mechanical problem with it's current location we may go this route. |
We did not experience breaker issues while also running an intake motor & compressor. We also did not perform any type of current sensing. Last edited by lynca : 03-11-2014 at 08:57. |
Churros are not recommended drive axles, but they work well for a quick prototype. We did have enough black hex VEXpro shafts on hand at the time. |
#10
Here's why:
+1. That kind of reduction will result in an extremely low speed, around 5 fps according to JVN design calc. Not really worth a 4 cim 4 minicim drive IMO, as even in high gear mecanum you're only running 12fps...
#12
Free speed of CIM+MiniCIM motor combination geared 1:1 = (343 + 198) / (343/5310 + 198/6200) ~ 5604 rpm vehicle speed (with traction wheels) @ motor combo free speed = (pi*4*5604) / (720*12.75*40/18) ~ 3.45 feet/sec Last edited by Ether : 08-11-2014 at 14:41. Reason: added link to graph |
#13
Getting there!
https://www.facebook.com/video.php?v...04577359603811 |
#14
Congrats on getting to the movement milestone though! |
#15
We actually tested this last year with a force gauge, it takes ~15% more force to pull/push the robot side to side or front to back (with locked wheels) because when you put it on a diagonal more nubs are touching the carpet per contact patch area. |
