Re: pic: MOEnarch Swerve Drive
Is it a fair assumption that you will be using 8 CIM drive with this.
If so, how are you planning to keep from popping your main breaker? Are you using current monitoring to keep yourself in a safe zone? |
I would consider changing the location of your digital encoder for a couple reasons.
First, as you tension the belt by moving your cim, it will change the engagement on the Digital encoder. Secondly, generally speaking those things don't appreciate a lot of side-loading. Third, if your belt slips, your wheel will no longer be aligned with the encoder reading. I'd consider a small lightweight bracket that places it directly over the primary shaft of the module itself, so you'll always know the true position of the module. This also relieves any side-pressure on it, and it can be coupled with something as simple as surgical tubing. It will probably be a wash weight-wise. |
We did consider a bracket like you describe but it was just another part to manufacture and would also put the encoder in a more vulnerable location. If there is some unforeseen mechanical problem with it's current location we may go this route. |
We did not experience breaker issues while also running an intake motor & compressor. We also did not perform any type of current sensing. Last edited by lynca : 03-11-2014 at 08:57. |
Churros are not recommended drive axles, but they work well for a quick prototype. We did have enough black hex VEXpro shafts on hand at the time. |
Here's why:
+1. That kind of reduction will result in an extremely low speed, around 5 fps according to JVN design calc. Not really worth a 4 cim 4 minicim drive IMO, as even in high gear mecanum you're only running 12fps...
Free speed of CIM+MiniCIM motor combination geared 1:1 = (343 + 198) / (343/5310 + 198/6200) ~ 5604 rpm vehicle speed (with traction wheels) @ motor combo free speed = (pi*4*5604) / (720*12.75*40/18) ~ 3.45 feet/sec Last edited by Ether : 08-11-2014 at 14:41. Reason: added link to graph |
#10
Getting there!
https://www.facebook.com/video.php?v...04577359603811 |
#11
Congrats on getting to the movement milestone though! |
#12
We actually tested this last year with a force gauge, it takes ~15% more force to pull/push the robot side to side or front to back (with locked wheels) because when you put it on a diagonal more nubs are touching the carpet per contact patch area. |
#13
Looks like a happy happy joy joy moment. Some thing does not sound right when the module was rotating and driven. Those are wide wheels and may cause problems with amp draw on both drive motors and steering. Pay close attention to the tuning of the steering pid. You can have to much traction. For a fall back you might want to consider 1-1/2 or 1-1/4" Colsons. Next, get 4 of them on a frame and get programming. Then you will be half way there. Driver training is the last half. If you get it going before kick off, do you want to meet and do some swerve on swerve driving?
Note for the drive encoder, Do you really need quadrature? Wouldn't a tachometer solution be good enough? I do not now what the under side of the coaxial pulley looks like but, could you put some reflective tape strips on it and use a optical reflective sensor? We used a magnet solution last year and will use optical this year. Last edited by Gdeaver : 20-11-2014 at 08:33. |
#14
) If you were referring to the pulsating of the sound I think that was because most of the noise was coming from the bevel gears and their location was changing relative to the mic, but I will look into it. Do you grease yours? We also have not played with tension of the rotation motor belt, we will look into that next meeting (we did notice it affected the speed of rotation between modules) We will definitely be keeping an eye on the amps and have Jags on every motor to monitor that, The RoboRIO should also make that easy when it arrives. We will hopefully get driving by Monday. Our programmers already have a basic crab drive program and are working on fancier moves now. I think we would love to have some swerve on swerve driving! You and your team have already been a great help this summer, I will ask the drive team about this at the next meeting and get back to you. As for the encoders we debated this, but we haven't had very reliable results from magnetic sensors in the past, and there is not much room to mount an optical sensor under the pulley. We also had all the encoders we plan to use in stock so we just went with them. |
#15
